Originally Posted by FUNFER2
Did you end up ordering paint from Ranger Tire Paint? If yes, was it the White Side Wall paint?
Probably a silly question, but what's the standard relating to which part of the lettering gets painted - specifically, is paint applied to just the inside of the lettering - leaving the raised rubber that surrounds each letter black or is the raised rubber sides part also painted? In other words, which is the end point on each side for the best look and for easy maintenance?
As my tires arrived, there is no telling what was suppose to be painted as paint is inside, on the raised rubber sides and outside that point - sort of like someone had a stencil but didn't bother to place it correctly or completed the job in under 5 second per tire. Just sort of pisses me off, but that's life.
