Thread: T4 to T5 swap
Old 11-10-2001, 05:49 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Have same setup only using 351W instead of 302.
Your 302 has all the late goodies, 10 1/2" clutch?
You'll need a late '84 up Mustang 5.0 bellhousing and clutch fork.
The CR clutch cable setup sux. If it's working for you OK, I guess leave it alone. If not, I grafted a late Mustang aftermarket clutch quadrant so it could use stronger late aftermarket cable and firewall adjuster. Have digital pix, not difficult. Smooth, easy clutch action.
If you're using stock rear gears, 2.74, and you never push the car, a junkyard T-5 is still a roll of the dice. Early non-World Class T-5's were only rated for 260 fptq. It will blow if you screech it.
It's not uncommon to pay $500 - $700 for even a used T-5. Then you have to at least put new synchros and a steel throwout bearing retainer in it. To do it right with new gearset is another $500. Hate to say this, but the only safe way to get a good T-5 is to buy one new. The close ratio, heavy duty "Z" models were not used on any production vehicles.
If you need a starter too, the Powermaster is about 1/3 the weight and 3x the service life of even a new OEM Ford starter. $159 from Summit.
