Thanks
I purchased the pliers.
Do you think it is a good idea to rebuild it when the body comes off. Keep in mind I will not be able to test the tranny until the body goes back on.
Then the body will be painted and I would hate to lean over the body after paint has been applied.
Basically, can I turn the input shaft and check the output shaft for the engagement of the different gears?
