  #24 (permalink)
Old 04-02-2009, 05:12 PM
dvcobra dvcobra is offline
Cobra Make, Engine: Classic Roadster 427SC, 351W bored .30, Edelbrock Performer RPM Package, Tremec trans, Currie 9" rear end.
Curt, you said you are running QA1 coilovers 500lb in the front. Do you have a part number? Are they adjustable?. I also noticed that you have run at Willow Springs, I will be there on May 9 & 10 for the COCOA event if your interested in joining us. Do you know what kind of times you were running out there with your setup?
I was out there last week and I still am experiencing a lot of body role and the back end wants to come around when I push it too hard. Do you think changing from the Carrera 350lb coilovers to the 500 lb. will eliminate some of the body roll and keep the back end on track?
The boxed lower control arms and heavier rear springs helped with the body roll, but I still need less roll I think.
I was amazed to hear that the FFR Challenge cars are using 700lb springs in front and 500lb springs in rear! Is that because of the 3-link and different front style suspension?
