Old 04-02-2009, 05:25 PM
rustyBob rustyBob is offline
Maybe.......a bad ball joint????? grab the top of the tire and shake the front wheel in and out and listen for the clunk or pull the front wheel and see if you can move the spindle in and out to see if the ball joint has slop in it . Sounds like you checked just about everything else so the ball joint may be the problem.......good luck
