Now if you had Webers...................Double the trouble
Back to the Demon-- I have found several where the throttle shaft is 'loose' where fitted to the linkage arm. Since the arm has the idle speed adjustment, the shaft & throttle blades have a mind of their own with a random idle speed resulting.
