Old 11-11-2001, 07:56 AM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Niles---
I put bolts thru both of mine. Also, I went out and looked and I have about a 1/4" of play to the bolt. My motor doesn't torque over at all, and I have never broken anything @ the sidepipes as BP mentioned (mine do mount to a solid flange, no tubes and no leaks!). Just drill the holes as close to center as you can so there will be enough meat around the hole and you will be fine. Niles, I also said perpendicular to the block--I meant to the mount. Just drill straight thru in the best location you can find.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
