switch from small block to FE in a Superformance
My friend Richard has a Superformance and wants to make the switch from a 351 small block to a FE 428 Big Block.
The motor will be stroked. He still needs to build it.
He wants to know what parts are needed to make the swap. Currently the transmission is a 5 speed. Not sure if it’s a TKO with internal hyd. throwout bearing.
Header… where do you purchase them?
Motor mounts?
Bell housing, flywheel, clutch and pressure plate.
Starter?
Morgan LeBlanc
Fresno CA
