Old 04-06-2009, 08:09 PM
Great Asp's Avatar
Great Asp Great Asp is offline
Cobra Make, Engine: SPO 2715
Originally Posted by Got the Bug View Post
Anthony,
Here's a link to a thread with the PNs/supplier to build an AN oil pressure hose specifically for the SPF (if you decide to replace your plastic hose at some point).
Best way to access back of oil pressure gauge
This is worth while. I had the funky platic line replaced when KCM installed the motor in 2715. The plastic line leaks at the fitting going into the motor on a lot of cars, as the fitting gets hot, and the engine torques up working the little brass ferrul into the plastic hose.
Don't ask why SPF does not give you the braided line from the factory.
If they did, you'd have no tinkering to do on your own.....
E
Bug, good post on the parts!
