Hi Larry,
Your plight is common with hydraulic throw out bearings. The bearing retainer should be sealed with anaerobic sealer and NOT RTV. The anaerobic sealer needs to be completely removed with carb cleaner & a razor blade. Be sure to install the proper shims that preload the front bearing.
I have developed many external billet slave/ fork combos so hydraulic throw out bearings are not used. When the hydraulic t/ob fails it will be a hugh headache just like you have learned.
Call me with any questions....
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
