I've put a Ford Laser column in mine and the advice from a well known sparky is that the wires use standard Ford colour coding, so I should be able to cross check with most Fords from the same era or a workshop manual, etc. Perhaps the same is true for Mitsubishi?
Failing that, perhaps time to get out the test light.
