Old 04-07-2009, 09:40 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Sounds to me like the old pump either has a short circuit or is encountering a locked rotor condition. Either one will cause the fuse to blow. You need to either replace the bad fuel pump or figure out if you can use only one pump and permanently remove the second one.
Chris
