  #36 (permalink)
Old 04-08-2009, 07:24 AM
patrickt patrickt is online now
Originally Posted by madmaxx View Post
Be carefull with the infered guns, if the emmissivity value is off you reading will be off by 30 degrees. I am sure the default value is 1 which is good for a flat black surface. #2 the cheaper one, less than $30K it takes an average of temps, if you are 1 foot away it is probably averaging a 8" diameter circle so put it right up on the component. They are best used to check for realitive change not absolute temp, now get an IR camera looking at thousands of points we are differtn
Or, you could take shots using your IR gun at a cup full of water and ice, and shots at a pot of boiling water on the stove, and see how close they are to 32 and 212. If you can get, say, a 150 reading from a pot of boiling water (and you're not at the top of a mountain) then it's time for a new tool.
