Old 04-08-2009, 05:05 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default problems with my efi
ever have one of those moments?
i've had efi problems for about 2-3 weeks now. it's an accel dfi gen 7 setup and runs in sequential mode with crank trigger and cam sync distributor. the problem is a code is set that indicates it has lost the crank signal. when this happens the efi goes from sequential to batch injection, and the tune runs rich, so you can't tune for one and have it work for the other.
i discussed it with the guy i purchased it from and we decided it must be interference, so i rewired all the efi stuff seperately from the power wires and msd and anything high voltage and interference looking, moving all the hardware to the other side of the car.
last week i thought i had it whooped, but the code came back again, so i was going to change to a dual sync distributor since i couldn't find the problem and try it that way.
tonight i was out there tracing all the wires to make sure of everything and still couldn't find anything wrong, so i pull out the voltmeter and start checking stuff and narrow it down to the crank trigger wire.
after going back and forth with an ohm meter and continuity checker i discover one pin in an 8 pin connector was not crimped properly. i could push the probes onto the pins and it would read and so i kept going back and forth and thought it was the wire between the connector but it would check ok. on the last go-around i narrowed it down to the pin which was intermittent and didn't have a good crimp on the wire, the wire slipped right out and was only held in with the rubber o-ring.
about 30 minutes prior to this i was about ready to give somebody big bucks just to find this.
anyway, that was my moment, and it lasted 2 weeks.
actually, 4 wks after i was kicked off the dyno!
