Thanks!
FWB, thank you! I didn't realize the diff in part # vs. engr'g #. Ports do look good, so I'll plan on using it. And, I've made all of the mods to the oiling system on the block; main bearing saddle holes to line up with bearing hole, block to filter adapter, etc.
thanks again,
Joe
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
