Originally Posted by madmaxx
my guess is it where your water pump bolts to the block. Notorious for leaking there.
Especially the bolt that holds the alternator on and passes through the water pump. I had to replace an alternator on my Roush and when I removed the bolt coolant started dripping out. As soon as I snugged the bolt back up, the drip stopped and I haven't had any problems. Agree with Blas, clean it up and then investigate (coolant can go everywhere). If you can't find the source, you can try a dye kit and light.
