Originally Posted by Naboo
I have 315/35/17 tires on the rear and when I go over bumps, the driver's rear tire rubs. If I install a thin wheel spacer (1/8"), will that be OK? Are there any other suggestions?
Installing a wheel spacer would probably make the rubbing problem worse. Raising the ride height is your best bet.
Doug
