Speaking of stopping, bring your best hooks. Turn 5, you go from 160 to 45 on a downhill, the most severe brake zone I have seen. The trickiest corner to slow down for is turn 12, better known as canada corner. I can barely get my cobra straight enough to hammer the brakes, cram it in to third and make the corner. At the kink, I tap them before, roll into it and hope I have room at the exit. I never push the kink as an accordian cobra is not to my taste. Don, if you folllow me, I will show you my line. After you see my line though, you will most likely be thinking" this can't be the right line" and you will be correct. But don't worry, I will only confuse you until the first straight. After that you won't be confused any more. scott
