04-13-2009, 02:14 PM
Carter M6905
I have similar specs to what you're building. The most common pump (and the one I use) is the Carter M6905. Yes it has 1/4" NPT, but it's spec'd at 120GPH @ 6psi. I'm trying to remember the last post I read where somebody with an FE around our size had a fuel starvation issue with that pump and honestly I can't even remember one.
