  #21 (permalink)
Old 04-13-2009, 06:35 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Sounds like that's your problem. The proper wrenches are available from Bilstein, and you must have 2. They are about $8 each plus shipping.
You'll need to adjust each wheel one at a time, then roll the car back & forth a little to get it to set up right, then do the next wheel. You usually start with a rear and go all around and then back to the first one you did and start again. Don't forget to use a jack stand every time you go under a fender, I know it's only for a moment to make a quick adjust, but it only take a fraction of a second to experience the effects of gravity first hand and to personally confirm that Isaac Newton and Albert Einstein were correct.
SPFWiringDiagrams@Comcast.net
