Thread: pull it?
Old 04-13-2009, 05:41 PM
madmaxx madmaxx is offline
Funnny you mention that, back in the late 60' early 70's gm made the timing gears out of nylon, after about 100k miles the teeth would break off and get in the oil pump then bang, it would break. I cut a square out of the oil pan under the oil pickup screen so I could access the screen without removing the pan which required engine removal.
Originally Posted by rdc767 View Post
Pulling the pan is a pain without a lift. I going to invent a pan that you can service the pump and check out what sitting on the bottom without taking off the entire pan.
