Old 04-13-2009, 08:22 PM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Default Thank you for your replies!
Thanks everyone for the good info!
Patrickt, what solid cam are you running in your 447? And, you correctly mention "strapping on the pipes"........does anyone know how the Gas N stainless steel pipes compare to the others? I've heard that they're some quieter, but no mention of hp loss compared to others.
thanks again, I'm on a steep learning curve!!
Joe
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
