Thread: Epoxy flooring
Old 04-14-2009, 03:46 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
I epoxy coated my floor 13 years ago with industrial epoxy. I didn't use the color chips but instead went with a blue color similar to that blue masking tape. Looks great and cleans up nice and takes a beating without lifting. I would recomend the color chips to help with the nonslip surface. Dust from woodworking and epoxy floor can be real slick. Water and epoxy floor can be real slick. Although no one has slipped and fallen it is a real potential. The other thing is when parking a car that has been driven in the rain. The water drips off the car but soesn't soak into the floor so it puddles. After a few trips out and back the puddles get bigger and bigger to where they will migrate across the floor. Yes I would do it over again, I am just sharing some negatives. I believe it is called Polyamide 2 part Epoxy, the same stuff used to paint the inside of a swimming pool. I recomend the best respirator you can find and have some good ventilation because this stuff can kill you. Also the guys that do this for a living will wear golf shoes with metal spikes to walk on an uncured floor. That way their feet don't stick to the floor. Good luck!
John
