Thread: Epoxy flooring
Old 04-14-2009, 03:25 PM
elmariachi elmariachi is offline
Originally Posted by MaSnaka View Post
I didn't use the color chips but instead went with a blue color similar to that blue masking tape. John
Yep, many of these products, including the 224HS can be tinted to any color you want. That allowed me to match the floor, chips, walls and cabinets all into a complete package.
Water and epoxy floor can be real slick. Although no one has slipped and fallen it is a real potential.
I wound up using a 1/2" nap 20" wide industrial roller to apply mine 9and it was a gooey PITA) but the long nap gave it a bit of a texture, which does help considerably with the traction issue. Even when wet, its tough to slip on mine. (But Goo Gone will sure make you bust your a$$ though.) When I applied the epoxy base, it was the consistency of syrup and I had to pour it onto the floor, spread with a squeegee and then smooth and cover with the roller. I would NOT recommend a 1/2" nap roller again, 3/8" wool is ideal. You can also buy sand to mix in for traction control, but based on how much I roll around on the floor, I didn't want to feel the the grit. As John said, you will need spike shoes to walk on the epoxy as you spread it, especially if you use flakes. I made some from an old pair of tennis shoes with drywall screws screwed through the soles and on through some 1"x4" I cut the length of the shoes. Worked well enough and allowed me to walk across the material to hit any spots I missed as well as to spread the flakes. I used a handheld lawn fertilizer spreader to spread them, worked like a charm.
Doing it right involves some planning and prep, and having a helper or two is a good idea as well.
