When I attached the aluminum flywheel I did not want the heads of the bolts (ARP) baring down on the bare aluminum. I obtained the metal ring that is used with a flexplate in and Automatic trans application, it's a pretty common piece. It has the 6 holes in a ring the diameter of the crank flange, and distributes the clamping force a little more evenly IMO. It is made of a semi hardened material. Red Loctite all the way. No regrets.
Ronbo...The Green Loctite is for small diameter fasteners to be "Wicked" into the threads after assembly. It's not a high strength thread locker.
Rick
