Hi Gary,
Are you running a 428 crank? I would think they could drill out enough material to create the correct external balance correction for the 428. Does McCleod offer an aluminum flywheel already set up for the 428? You might want to call David Kee to see what he has in stock as this may be safer than compromising the flywheel you already have and you can just sell it to someone with a 427 crank.
Gary
