Yes I am running the 428 crank and McLeod does offer one like I said....it's a zero balance with a bolt on counterweight so you can use it either way.....what we're curious of is that there has been so much material taken out of the original flywheel to create the counterbalance that we're not sure if they just took out enough for the counterbalance or whether they took out addittional material to bring it all into balance and if the bolt on counterbalance would be in sync with the original. I had already talked with David and it was his suggestion to see if someone could balance the new one to the old one without having to take down the motor again. The machinist suggested a new one with the bolt on counterbalance but we both agreed we were not sure if it would be close enough or not.
Gary
