Old 11-13-2001, 01:43 PM
Coloradocobra Coloradocobra is offline
Hi Gary,
Any good balance shop can determine the phase angle of the unbalance in your old flywheel (the position of the heavy spot with respect to the bolt pattern) as well as the oz-inches of unbalance. They can then replicate this on your new one. Based on what you have said about this bolt-on plate, I would bolt it on and then simply "trim" balance it to get it to precision. In other words, bolting it on may bring it to 28.4 oz-inches at 89 degrees (made up the angle). At 5000 rpm you would probably never feel the fact that the balance was not perfect. At the 11,000 rpm you spin that stroker, they would have to perform some creative drilling to move the position of the heavy spot a few degrees and set it to exactly 28 oz-inches (or whatever your old flywheel was). No need to tear the motor down, just replicate what you already had.
Before bolting the flywheel on, use a machinist's stone to make sure the faces of the crank and flywheel are free of burrs and check for axial runout once you have it bolted on.
Good luck,
Gary
