Old 04-16-2009, 01:06 PM
GreenSnakeDoc GreenSnakeDoc is offline
I've got the same waving needle problem with my LAX (now B&B). LAX built the car using a Ford gas tank and sender. The sender was not compatible resistance wise with the Stewart Warned fuel gage. When the gage read 3/4ths full, the tank was near empty. I bough a "universal" S&W sender on ebay and its resistance values allow the fuel gage to read properly. This was not an easy install as I had to graft the S&W float and rheostat to the stock Ford pickup tube and seal plate. The gage now reads "true"; however, when driving, accelerating, braking and turning, the fuel in the tank sloshes back and forth causing the float to go up and down making the needle wave. Go to ffcobra.com and search for "slosh". This situation is expalined in great detail, and one electical wizard develped an anti-slosh circuit to prevent needle waving. It seems to have been a common problem with some Mustang tanks that were not internally baffled to the extent that many Mustangs had a factory anti-slosh circuit built into their dash.
