Originally Posted by onefast5.0
Hey just wanted to get some opinions on a rear end? I found a pretty nice 9" ford rear end,is this the one that I want to go with or should I go with an 8.8"
Either rear should be fine. The 8.8 may infact be the stronger rear. I know the pinion gear has a much thicker shaft, and it may have a better angle engagement of the gears, leading to better efficiency.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
