Old 04-18-2009, 12:38 PM
427AC 427AC is offline
Default Diff
Hi Lads thanks for your knowledge.
Ye managed to get hold of a 4HU Unit jag irs today but theres no front mounting holes for the four bolts on the front. And would i need to convert the output pulleys to be the same as the front pulley. to take the drive shafts.
Not sure if there is a conversion kit about.
Could do with someone with a csx to get the numbers off there diff if that's ok.
Using the same set up as origanal chassis have got drawings from cobra restorer.
Will post pictures when done.
Thanks again.
