Originally Posted by undy
Eric, The flutter occurs when the mufflers are installed as they are intended, for max sound attenuation. When I installed the inserts before, with the louvers being ineffective for max flow and minimal sound attenuation, there was no flutter. This flutter issue is very wide spread, not just your systems (no pot shotz at CC intended here at all, I've always been happy with your stuff and customer support).
You have any thoughts on this flutter issue??
Dave
Hi Dave. Just a note on the Stainless Specialities mufflers. They do not have a directional louver within them. It's a stainless steel mesh that holds back a ceramic blanket material. I would also suspect that the blanket material gets coated over a duration, as my pipes are louder today than they were when new. WOT will alert every police officer within a 1/2 mile radius (maybe up to a mile if they are down wind.). Ear plugs are mandatory and I have just gotten used to using them all the time now. They also cut down on the wind noise when doing 70-75 on the interstate.
-Dean
