Old 11-14-2001, 06:04 AM
Lincoln Lincoln is offline
Default HEADS FRESH, LIKE ALL THE ENGINE
I do not seem to be getting the typical, valve guide, blow by. I think, that it is going out, the tail pipe, When running down the road, at speed. I drove her to Oregon, 250 miles and used no oil. Put new mufflers and tail pipes on and kept the same H pipe. Used a quart, coming back. Commute about 100 mi a day and seem to be using a quart, every 2 or 3 days. It may be, that the baffle is out of the valve cover, as suggested, that, I will check today. I may, pull the PCV, and see what happens. I have noticed a significant increase in power, since the exhaust was added.
Thanks for the input...
