Engine Specs from Comptetion Motor Sports in Ross, Ohio:
408 Windsor Stroker
Block:
Seasoned Pre-1974 Casting
Thermal Cleaned, shot blasted and magnafluxed
Alinehoned and True-Decked
Cylinders bored and powerhoned
Brass-Freeze Plugs
Rotating Assembly:
4340 Forged Steel Crank (4 inch stroke)
Computer Balanced
Eagle Rods
JE Forged Pistons
Plasma Moly Rings
Aluminum 8fi flywheel
Components:
Edelbrock Victor Jr. Heads and Intake (Polished)
"Cobra" valve covers
Race Demon 750 CF double pumper
High Rev Lifters
Chrome moly pushrods
Aluminum Rocker arms
True Roller timing chain
Perf. coated bearings
MSD billet distributor
Canton Performance Pan
Melling High-Perf.
Oil Pump
Heavy Duty
Oil Pump Driveshaft
ARP Head and main studs
March Perf. Pulleys
High- Perf. starter
Billet Air cleaner with K&N...
Sorry you are down on the roundels....
Andy
