Old 04-20-2009, 04:23 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by RedBarchetta View Post
Mine is mounted similarly to Jim's. We both fashioned a plate to mount ours on. He mounts his closer to the fans and mine is more offset toward the motor. Niether one of us centered it on the cross-member, as you will discover with the mounting bracket that this makes it difficult to do so. This isn't the best pic (Jim's is more of a close-up), but at least you get a feel for how it looks in the whole engine bay. I still haven't come up with a cleaner way to route the plumbing from the remote oil filter exit back to the intake on the thermostat. Have considered some hard line but the bends would be too tight. Maybe Jim can share with us an underneath shot...his looks cleaner.
Overall I'm pleased with this unit.
-Dean
I think I need one of these as my oil temp rarely gets off the bottom peg and when it does only goes up to about 60*C. Water temp is about 80-85*C. However, I'll also need to find the braided hoses in the right lengths. What lengths/sources did you use?
