Originally Posted by blykins
If the cam is already broken in, the oil isn't really that critical now.
The tall and skinny of it is that if you want to spring for it, Brad Penn would probably be the best oil for the engine. However, it's high dollar. I would just use a good Mobil 1, Valvoline, or Rotella oil in it, don't worry about synthetic.
As for plugs....what ignition are you running? MSD? Duraspark?
A good Champion, Autolite, or Motorcraft plug will be just fine.
thanks for the quick reply,
what oil weight is best to use.
its not a new engine so the break in is not needed. as for ignition, its a msd box, what about spark plug gap? what is recomended.
