Old 04-25-2009, 05:43 AM
Mdman352's Avatar
Mdman352 Mdman352 is offline
Cobra Make, Engine: Contemporary-427 stroker
Default Check this as well
Doc,
I had a similiar problem. What i fouind was the lower radiator hose was collasping at higher rpm. the fix is, buy a hose with a spring in it, or get the spring out of a hose and insert it into your hose. this will prevent the hose from pinching off water flow. Rev the motor up and what what happens to the lower hose. Hope this helps.
David
