Any thoughts on a mini starter Bill?
WildBill3 Bill any thoughts on a mini starter? Call Summit of Jegs for INFO ONLY. I would try and e-mail Keith Craft or Brent B. to check with. Either one should have the correct answer. Years ago They had short nose, long nose, manual, auto trans, & heavy duty starters all would work on the same motor and flywheel. If worst comes to worst, machine out the backing plate where the starter is mounted. Or machine the mounting housing on the starter. This will void the warranty. Rick L.
