  #23 (permalink)
Old 04-26-2009, 05:17 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by onefastmustang View Post
Well it is finally fixed.... Yay... I went crazy with all of the suggestions that were given to me and it is now running great and not leaking..
Thanks all. Here is what I did for those curious.
1. Sanded the top of the engine to make it a bit coarser, same with bottom of the intake.
2. Stippled the intake and the engine block.
3. Cleaned really well with cleaner.
4. Applied Grey RTV down both end seals and let sit 15 minutes.
5. Torqued to spec and let sit overnight.
6. Installed a PCV valve in the left valve cover to create negative pressure in the motor
7. Drove it 100 miles today, not a drop of oil leaked.
Yay..
great news. glad it worked out.
how did you end up plumbing the pcv into the weber manifold ?
Z. Ray
'65 K code Mustang
'66 Galaxie 500
