Reverse lockout T56
Hello everyone.
Last night I reassembled my selector assy with a modified selector hub assy, so it has the detent for reverse lockout.
I tested after refitting and found the reverse lockout is working correctly (ie can not select reverse by mistake), but I have now discovered that the solenoid is not pulling itself in either.
To the guys who might know, is this solenoid 12v drive or is it 5v?
I will be attempting to make it work correctly through the ecu, but I need to make sure the car is driveable (forward and backward) by sunday 10th May, so was thinking if worse case I might have to wire in a switch to select reverse and drive the solenoid.
Did not want to do this if the solenoid is 5v through fear of burning it out.
Cruising in 5th
