Old 04-28-2009, 08:33 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by Caprimaniac View Post
As spring comes in and the snow melts, the 347 awakens. The engine was started yesterday, and everything looks good.
As a refinement for this season I thought I'd make the fuel pump a bit more quiet by installing a piece of hose between the pump and the aluminium line that runs the lenght inside the car. Although it sounded promising when the pump was run dry, the enourmous whining and grinding came back as soon as fuel was poured into the tenk once more....
The pump is a Summit 130 gph "racing" unit.
And to be honest, it makes alot of noice. - OK; no sound of it as soon as the throttle is "halfway there and beyond"- but a pain in the ass when in traffic. (Anyone else has the same experience?)
Any reasonably priced less noisy pumps you'd like to suggest?
( The engine sports 4 x IDF's and I use an Aeromotive adjustable regulator with a 1/2" return line, 3/8" supply.)
Happy Springtime
RuneS
Two solutions for you:
1) Checkout the Weldon 600-A. This is a very reliable and quiet pump. I've been using one on my Street Vette (blown and injected for several years now)
2) You can use an Aeromotive Inline Pump (Summit AEI-11101) and a fuel pump controller. The controller will slow down/quiet down the pump below 2500 RPM which also extends its life
Both of these pumps will require a regulator and a return line and both should be good for 600+hp.
-Fred
Last edited by fkemmerer; 04-28-2009 at 08:36 AM.. Reason: Forgot an important detail
