Thread: Engine Failure
  #34 (permalink)
Old 04-28-2009, 05:14 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
were any of the other rod bolts loose when you took them out????
That picture of the main stud length is questionable as to the ability to get proper strech/tension
And I am not reading that you used a strech gage on the rod bolts????? What did you torque them to and what did you use to lube the threads/heads???
Your damage is consistant with a bolt coming out, the cap then breaking the other bolt off---no apparent bearing/oil problem----
