Thread: Engine Failure
  #45 (permalink)
Old 04-29-2009, 01:50 PM
olddog olddog is offline
Originally Posted by Jerry Clayton View Post
the MOST important factor was because it took oil away from the engine when it needed it MOST, refilling the sump after a long hard braking/corner portion of the track---3 quarts of oil--how long does it take to pump 3 quarts of oil???? how far does your car travel in that time frame?????its like a huge leak in your oil system, taking the oil away from your bearings (and those wonderful roller rockers)
Interesting point. So after the accusump saves the engine from a total loss of oil pressure, it causes a low oil flow to the engine as oil is diverted into the accusump to refill it.
Wouldn't a flow restrictor in the direction of filling the accusump slow this to a negligable rate and still allow full flow to the engine? I know there is directional flow restrictors for compressed air and would assume they are made for oil as well.
Certainly a dry sump oil system is better.
