Old 05-01-2009, 08:38 PM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Originally Posted by Rwillia4 View Post
You will love the T-56!! The shift is probably one of the nicest I have felt and way better then a TKO. The shifter hole is in the exact same spot as other trannys. The tranny also comes with a bell housing (is it not steel or a scattersheild). It is longer then a standard transmission and a little wider. You will probably have to shorten your driveshaft.
I have pushed more than the tranny is rated for and have had no problems, I believe this is due to the light weight of our vehicles.
Actually the Magnum is quite a bit different than the T-56 you have. Though I am waiting for the product to mature a bit before we start using it.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
