Old 05-02-2009, 03:52 PM
Keith58 Keith58 is offline
Cobra Make, Engine: Magnum 427 SF, Edelbrock Performer RPM Stroked Ford
Talking Help with 418 stroker engine/trans for UK Cobra
Hi
I am currently rebuilding my Magnum Cobra here in the UK and am looking for some advice.
I have started an engine assembly based upon a 351W with a Coast High Performance 418 stroker kit and Probe 22cc dished pistons.
I have looked at AFR heads and qustion whether for a mixed road/track car that the 225 heads would be too much and I would be better going with the 205?
What would be the best cam, inlet manifold and carb for the setup usng a Tremec TK600 box and Jaguar/Quaife limited slip differential with a 3.33:1 or similar ratio?
Would also appreciate advice on using a throw out hydraulic clutch release mechanism as opposed to a standard slave cylinder with pushrod & lever.
Advice/experience/guidance much appreciated.
BTW this engine is replacing an Edelbrock 343 stroked 302 as I am looking for more power - over 500 horses.
