thanks for the info jason
i understand mounting the calipers, usually can center over the hubs with pedal pressure and use shims at the mounting holes.
i'm trying to follow you when you say spindle do you mean hub? check the rotor mounting face with the hat on the hub first, which would be on the spindle?
i checked the runout on the front with the wheels mounted, just jacked it up. i guess i should check the parts seperately is what you are saying? like the hub mounting face.
the part numbers are 160-3874, 160-3875. i inquired via email and got the no go, i've searched the net and can't find them either. i noticed they do not list the 1.38 calipers for them anymore.
thanks for the compliments on the engine. prob took 6 months to build by the time all the parts were accumulated, machine work corrected, information gathered, etc.
this one is 406ci, it would be pretty scary to have 565ci under the foot! i'm sure you'll enjoy yours when it is finished.
mark
