Old 05-05-2009, 06:41 PM
Barry_R Barry_R is offline
Normal - that is a place where all the oil from the block will eventually drain while sitting - its a bypass right? The pan does need to be flat - especially when sandwiching a windage tray and two gaskets - so you have your problem identified.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
