the wheels are 17" x wide.
all the stuff on this car is made for stout.
maybe sometime i will change to a lighter rotor, but as long as these are working i will prob stay with them unless somebody comes up with some carbon stuff and wants me to check it out.
i think the front brakes have air in the line from what i can tell, i can pump up the brakes and the shimy is not as bad, prob the reason for the rears overheating and warping. they are about 7-8 thou out each.
i would hit the brakes and come off them and then when i hit them again they were not as bad and almost smooth, kinda wierd and hadn't experienced it before. only thing i can tell is fronts have air in the line but i'll check everything on the rear to make sure.
you think the rotors are heavy the tires are about 47 lbs. (rear). i'd like to change them and the rotors out. i remember weighing wide 5 rims w/tires and they weighed right at 20 lbs.
