Old 05-06-2009, 07:44 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
To fix it right, you'll need to completly remove the windshield/frame assembly out of the car and lay it out on a blanket or something. The side frames will unscrew and then they will pull off fairly easily so you can swap em. Reversing the side windshield frames is a common and easy mistake to do, I've seen it a lot. If you decide to do the bending thing, they do bend easy because they're made out of brass. Just be careful because the chrome can crack.
" It ain't no big deal"
