Robert,
You may need to add a gusset to the park brake bracket on the bottom side of your Backdraft. It tends to bend while applying the park brake.
If you have adjusted the park brakes in the rear once, then twice then you know something else is the problem. This is a very easy fix. Just need to add a gusset on each side to prevent movement.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
